How to stop water leaking out of gutters?
flummoxed01
Growing in Experience
Hi everyone! I have a small issue with my gutter—it’s not clogged but water seems to drip out. I’ve checked for blockages, but everything seems clear. I’ve captured a video showing the problem. Looking for some DIY advice on how to fix this. Any tips or suggestions would be greatly appreciated!
Re: Water leaking out of gutters
Afternoon @flummoxed01
I think they look like the right ones, The gutter needs to be removed first before installing them, I would use a pencil and draw the existing fall on the timber that your gutter is hanging off of.
The Gutter "folds" into/onto the clips, So if that one you have in your hand is mounted so the left hand side is flush on the Eve. Then when you go to clip the gutter in, tilt the gutter so its angled at 45degrees, then the high side of the gutter (with that groove on the edge) will fit into that circled end. Keep that circled end in the groove, Then you rotate the gutter down and the rear of the gutter should clip in to that edge with the hole in it (next to your finger and thumb).
Hi @flummoxed01,
As @Dave-1 has said, a gutter clip can't be retrofitted without taking the gutter off.
If you search "quad gutter install" on Youtube, you will find videos showing what Dave has described.
Let me know how you go.
