How to stop overflowing water from other properties?
I have an existing colourbond fence as a boundary fence between my property and the adjoining property.
I continually have flooding when heavy rain pouring through from their place. It is like a dam has burst and we have renewed all of our storm water and drains at a cost of $9000.
Our drainage accommodates water on our property but not the extra from behind. When this happens it floods the top level which becomes like a swimming pool and over the garden and is like a waterfall coming down over the steps to the patio. When the water gets to the patio we have to broom it to the side so that it doesn't enter the house. We have had to have SES provide sand bags.
We have spoken to the neighbor who says his yard floods as well but says it is nature and is not prepared to do anything .
We have spoken to the Council on a number of occasions and one again they are looking into it.
We are having quotes to build a wall across the back but this is very expensive. We thought we would get cement sheeting and put that across the back to prevent this flooding. We were thinking of making it approx 3ft high. and to go across approx 405ft
Not sure what product to use and really need help.
- Labels:
Fencing and Screening
Plumbing
Re: How to stop overflowing water from other properties
Hello @Barbara35
Let me tag @mort57 to make them aware of your offer. I'm sure that when they read your posts, they will find the information very handy and useful.
Hi Eric,
Is it possible to speak to you on the phone?
Hello @Barbara35
You can send me a private message if you need assistance. I'll answer it from that end.
Re: How to stop overflowing water from other properties?
We did put a retaining wall across the bottom of our colour bond fence with treated pine sleepers three high with the bottom one half into the ground.
We cemented across the bottom of the sleepers and put silicone in the joins. Then packing the soil tightly against the sleepers.
The water then built up and then discharged through the colour bond fence behind out brick shed. So I cemented all of the joints in the colour bond fence across the bottom and up the posts this then discharged down the side of the shed so we then put a row of sleepers down the side so that the water would then run across the back behind all of the fence not allowing the water to come through. It now runs down the side of the yard and discharges down the side of the house and what our drains does not collect it then runs out into the street.
For the first time in years we have not been out the back in pouring rain sweeping the water away from the house. Most times calling SES for sand bags to stop water entering the house.
Actually the last time SES came they suggested putting the and bags at the back fence but the boss then told them they couldn't do that but w thought why had we not thought of this stopping the water from the source.
So that is why we spent the time and money to do this and so far fingers crossed it is working.
When we had this last torrential rain it was so nice to sit back and watch the flooding go down the side of the house and out into the street.
Hopefully this will continue.
I hope this helps and if the team think it would help I would be prepared for you to see what we did.
We found that treated pine sleepers with post cemented into the ground with the first sleeper half into the ground and about three sleepers high.
We also cemented along the bottom of the sleepers and put silicone in the joins.
It is fantastic to hear that you solved your issue @Barbara35. Feel free to post some images if you would like.
Hi Barbara35,
I read about your ordeal and it sounds just like what I am currently going through after my next door neighbours did landscaping and pool construction. The stormwater that used to enter their property from the uphill neighbour has now been redirected to my property. I now have a river flowing along the shared fence line. The ferocity and volume of water is alarming. I too was sweeping stormwater from my back patio from 1am until 4am during a recent storm. My property has sustained a lot of damage as a result. I am planning on putting some drainage but from what you have described, it seems that I will also need to install a retaining wall. May I ask who did you get to do the retaining wall? Any help would be greatly appreciated.
Hi @Stormwater2024,
Thank you for your response and welcome to the Bunnings Workshop community, it is brilliant to have you join us.
I'm sorry to hear that you're experiencing some significant issues when it rains.
I know there are a number of members such as @Dave-1, @Nailbag, @TedBear and @Noyade that love helping to solve a drainage problem.
If possible, could you upload some images of the affected area? This will help us to give you some specific advice on how to address the issue better. Let me know if you require assistance uploading images, I am more than happy to help.
If you require someone to install a retaining wall, I suggest looking for a landscaper on a service such as Hipages or True Local. There don't tend to be large nation wide landscaping companies so it is best to look for someone local to your area.
Let me know if you have anything else I can help with.
Good Afternoon @Stormwater2024
Just a little bit of water 😕 Frustrating to happen.
Looking at your photos the right hand side next to the tiles is a drain? or a dish drain? Does it continue down the side of your house? And is there a downpipe anywhere along that rear tiled area? It looks like there should be with your roofed area to take away the water from the roof.
Easiest way would be to install a drain (dish drain) or a Everhard 3m EasyDRAIN Polymer Grate And Prejoined Channel against the rear of your retaining wall. And then have the water drain out through a pipe to either that low section of tiled area or if possinble to meet up with the downpipe piping. I dont think just a french drain would work for storm instances where you get immense runoff at one time.
Is their soil or tile under the bench seat area? You could potentially run the drain pipe to either side of the yard hidden under or inside the bench seat?
Subject | Author | Posted | |
a month ago | |||
December 2023 | |||
July | |||
July | |||
October 2021 |
