How to fill and redrill a misaligned hole in a concrete wall?
Klaus
I recently drilled two 6mm holes in a concrete outdoor wall to install a doorbell. The two holes need to be in a vertical line, but I accidentally drilled one of them at an incorrect angle. I would like to know if there is a product I can use to fill the incorrect hole so I can redrill it properly afterward.
Re: How to Fill and Redrill a Misaligned Hole in a Concrete Wall?
Hi @Klaus,
I'd suggest filling the hole with Earl's 1kg Concremate Expanding Cement. This is a shrink-resistant cementitious filler that should be perfect for this application.
Klaus
Hi Jacob,
Thank you so much for your helpful advice!
I have a follow-up question: the hole I drilled is approximately 3-5cm deep. Is there any specific technique or product I should use to ensure that the entire hole is filled properly?
Hi @Klaus,
Not really anything specific, I'd just use this Kango 10mm Tuck Pointer and keep pushing it into the hole until no more will go in.
Once it starts to overflow, wipe it off smoothly and wait till it's dry.
Re: How to fill and redrill a misaligned hole in a concrete wall?
Hi @Klaus
I just thought I'd add, similar to the curtain bracket, moving the holes slightly would be a good option. If the original holes are covered by the doorbell, that would be a simple fix.
