need to build 2 outdoor wooden ramps for wheelie walker entery to home, type of wood and any safety ideas, size approx
1 x 24" long x 30" wide ground level to 4" high
1 x 32" long x 30" ground level to 5" high
Hello @BJbear230247
Welcome to the Bunnings Workshop community. It's splendid to have you join us, and thank you for sharing your question about building wooden ramps.
I suggest having a look at this discussion - How to build a wheelchair ramp? by @Noyade.
It's important to consider the strength of the person using the wheelie walker. If they are not very strong, it will be necessary to lengthen the ramp so that they will be able to gradually go up the slope.
I suggest using MicroPro Sienna Sleepers in conjunction with 70x35 H3 treated framing timber. I propose using 1220 x 810mm 12mm Plywood Hardwood Marine AA Grade as the cover. I recommend using Buildex 10-8 x 40mm Climacoat Treated Pine And Hardwood Decking Screws to join them all together.
To prevent slipping, I suggest gluing a flat rubber mat on top of the marine ply.
I've placed a sample sketch below to give you an idea of how you could possibly assemble a ramp.
Please remember to wear personal protection such as gloves, goggles and a mask when working on your ramp assembly.
thank you, ERIC, for the advice
It's great to see that you found @EricL's advice useful @BJbear230247. Please let us know if you run into difficulties or have further questions.
