Hi
I was wondering if it is recommended to use pallets to build a deck and would it carry people’s weight safely and what I really do to treat it to prevent from moulding and rotting
Thank you
Hi @Mary1983
i would use pallets only as a tempory decking 2 to 5 years more if paint sealed. to lift things out of some mud etc but most pallets made from the cheapest junk wood that will dry rot quickly and the money you will spend trying the preserve it would be more wisly spent on treated pine as a minimum with built in endurance .
Consider making a basic treated pine frame and using yellow tounge flooring on it and deck sealing top and bottom it would be a cost effective option that will take a bunch of people and be mold resistant.
If you supply the deck dimentions and add a photo of the proposed deck area we can help guideyou through the steps and offer designs. If you wish.
Welcome to the Bunnings Workshop community @Mary1983 and thanks for joining in the discussion. It's great to have you with us.
Helpful member @Jewelleryrescue has already provided a wise reply, but let me also tag @Arcc who built low-level decks using recycled pallet timber.
You might also like to share more details about your proposed deck so members can give more comprehensive, specific and helpful advice. I'm sure our resident Bunnings D.I.Y. expert @EricL would be more than happy to suggest alternative materials to use.
Thanks,
Afternoon @Mary1983
I have often thought of using old pallets for decking and a few other ideas. As @Jewelleryrescue says their lifespan can be short. The hardwood pallets are usually kept by the freight companies and the lighter pine pallets I would not use.
If the pallets are kept off the ground and are the same size then I would say its doable. Do you have an idea on what surface you want to put on them? Most pallest I come across are beaten up a bit so you may wantto consider that factor.
At the very least I would be oiling the pallet with a timber oil (I am sure there are other products that protect, I just have been using it lately) I would be making sure there is no contact with the ground and the pallets are consistant in sizing.
Last question, could you showus a few photos of the area you are thinking of builing the deck, there may be another way to approach it and still use pallets.
Id also like to saw howdy and offer a warm welcom to the Bunnings community So many different answers in here and so many projects I am sure you will find a way for your deck!
