Small coffee table with folding legs by a novice
Krhodes
Hi everyone,
I would like to make a standard small coffee table to hold a cuppa and laptop.
I'd like the legs to fold in for easy storage but also need them to click into place when set up so it doesn't fall over.
I'm just having trouble in choosing what's best to use/what to use.
I know I need brackets for the swing but what holds it in place?
Thanks
Re: Novice small coffee table
Welcome to the Bunnings Workshop community @Krhodes. It's terrific to have you join us and we trust you'll get loads of helpful information, advice and inspiration for all your projects around the house and garden from our clever and creative members.
There's certainly lots of coffee table projects that have been shared by community members that you can get inspiration from. There's also a recent discussion about a folding table build kicked off by @Shagen that you might like to start with.
Here's some other posts you might find useful:
Hope that helps get you started.
Re: Small coffee table with folding legs by a novice
Hi @Krhodes,
As Jason mentioned @Shagen's discussion on their folding table covers this topic quite extensively and has responses from some of our most knowledgable members within in it. I'd encourage you to have a read through.
I believe the most simplistic way to achieve what you are after is to have the legs splay outwards with an angular cut on the bottom of them. When legs splay outward generally the table will not fall over. If you wish to have the legs click into place I would suggest using a Prestige 240mm Zinc Plated Steel Card Table Stay or Prestige 131mm Lid Support Stay to lock them in position.
