How to replace cracked mirror in sliding wardrobe door?
KeithClancy
I have a cracked mirror in one of those bog-standard built-in wardrobe sliding doors - I need a new mirror but also to install it in the framework and I have not had much success with finding out how to do this.
Any advice greatly appreciated! Dimensions of the mirror are 2000mm tall x 60mm wide (approximately as the mirror extends under the visible frame-edge of the door)
Re: How to replace cracked mirror in sliding wardrobe door?
Hello @KeithClancy
Welcome to the Bunnings Workshop community. It's marvellous to have you join us, and thanks for sharing your question about your wardrobe door.
In this particular instance, I suggest bringing your wardrobe door to a glazing and aluminium specialist. The trade specialist will be able to disassemble the door as they have the proper equipment for it, and they will be able to cut a new piece of glass to the exact dimensions of the old one. They will also be able to re-assemble it to its original form.
I don't recommend taking the aluminium frame apart as the glass is already broken and might break further if incorrect force is applied. The glass could shatter possibly causing injury.
