Hi Bunnings expert team
I am going to replace a plasterboard wall, could you tell how can I do it, thank you
Regards
Maymay
Hi @Maymay,
The tool to use is a score and snap knife. Once you have marked the lines you want to be cut you will then place a straight piece of material along the line as a guide. You need to run the knife across the board and along the guide several times to make a groove. You can then snap the board along that line.
There is no service available in-store to cut these boards. You can ask a team member to help you in cutting the board and they might be able to provide some assistance.
Hi Mitchell
Thank you for your great advice
Maymay
Hi Mitchell
We almost finish the job, do we need to silicone all around the Hardieflex wall ?
Thank you
Maymay
Hi @Maymay,
I apologise for the delay in my reply. You don't want water getting in under the edges around the Hardieflex. You can either use a Brutus 4.5mm x 2.4m Building Moulding Division to join the sheets together or seal the gap with Sikaflex 11fc. If you use the strip joiners they will stick up proud of the surface and there will be a visible join on the wall. If you are going to paint the wall then it might be worth going with the Sikaflex product and skimming it flat so it is flush with the boards surface. This will give you a cleaner result.
Hi Mitchell
Thank you for all of the great advices and methods
The job was done
Best regards
Maymay
Hi @Maymay,
That looks fantastic, you should be very proud of your efforts! Many thanks for updating us with a photo now that you are finished.
We look forward to hearing about your next project and can't wait to assist if necessary.
Well done.
Hi @MitchellMc
THanks for the great help you and @Jason are providing to the community.
i had a question on the above picture, where you have marked places to apply the adhesive.
Just curious to know, Why not apply on the middle cross frame and the outer frames?
thanks
Hi @bm,
You'll be nailing around the perimeter and the locations I've marked just show an evenly spaced layout (although my stars do look a bit wonky). You don't want to apply stud adhesive on your first or the last stud as when the glue drys it pulls the sheet back and your nails will then protrude. Here's a step_by-step D.I.Y. tutorial on How To Plasterboard A Stud Wall which explains in more detail.
Please let me know if you need further information or had questions.
