Good day,
A newbie DIY installer. I installed hybrid boards in one of the bedrooms and was wondering how should I fill this gap between tiles and the board. I am not sure if I should have cut the board appropriately to cover this extra space. The gap is about 50 mm.
Thanks.
Hello @brissy_carpent
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about filling the gap on your hybrid flooring.
I suggest cutting another strip of your flooring to cover the gap between your hybrid flooring and your tiled flooring. Please make sure to leave a 10mm gap between the two floorings. To cover the remaining gap between them, I suggest using a floor trim. The trim comes in several styles, I suggest visiting your local store so that you can see which one sill suite your needs.
Here are some discussions regarding flooring transitions:
