How to build a home theatre riser?
blackorange44
Hi
I want to build a riser for my home theatre.
The dimensions needed are 290 CM (w) x 190 CM (D) x 30 CM(H)
What would I need in materials and tools for the project.
Re: How to build a home theatre riser?
Hello @blackorange44
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about building a home theatre riser.
I suggest having a quick look at this discussion - How to build home theatre riser platform? by @Sergej. It's an excellent discussion that gives ideas on what timber to use and how you can assemble the frame itself. In order to assemble this frame, you'll need a tape measure a drill and drill bits along with a circular saw or hand saw. I propose looking carefully at the render so that you'll have a general idea of how the timber can be laid out into a frame.
Here are some discussions on how to build a home theatre platform:
I also suggest having a look at this excellent guide - How to build a dedicated home theatre by @Prof.
