Concrete table reno
Andadams
Having an Impact
Concrete table reno
I have finally finished my latest DIY project, which unfortunately took me over 6weeks from start to finish. But now that my table reno is completed, I’m pretty proud to share the outcome.
I bought a 4+ seater Freedom table and bench seat combo off Gumtree. It was the perfect shape/size that we needed, just didn’t match in with the other decor. It was a dark brown laminate, which had seen better days, chipped and scuffed from the previous owner.
I sanded back the laminate on the chairs and table to see what was underneath. It’s a pretty heavy unit so I was hoping it was something decent. The legs of both the table and chairs were a nice timber, the tops of the chairs and table were a thick chipboard. Which would still work well for what I needed.
I had done (what I thought) was a fair amount of research on concrete tables. I didn’t want to create a solid concrete slab just cover the existing table top. But the concrete was a bit of trial and error. First time it didn’t work, even after the back braking hours I spent smoothing, it just wouldn’t stick to the timber when dried. After extensive further research, I found the right cement to use and also a high grade clear/matte concrete sealer, and presto results! Process was time consuming and did end up costing more than expected, but hell of a lot cheaper than buying this new from a store. Now we can eat at our table again.
I lacquer the table legs in a nice natural stain and sprayed the chairs completely with a Black Satin for contrast.
Re: Concrete table reno
Hi @theparlourroom
That particular idea is actually being worked on. Hopefully, we'll soon have that functionality and you'll be able to save all your favorite projects into one place. In the meantime, I suggest saving it in your bookmarks on your web browser. If you've got a project lined up please don't hesitate to share it.
If you need advice or information, please let us know.
That would be a great function!!! I’ve definitely bookmarked this one 😊
ellebea
Community Newcomer
What products did you use for the concrete table top? Mine has a bleached spot and I need to try and repair it by maybe resurfacing it. It's grey. What clear matte concrete sealer did you use?
many thanks
Elle
