How to repair chipped Terrazzo table?
jessss
Hi there,
I have a terrazzo table that is chipped in a lot of places and am wanting some advice please on the best way to repair it. It weighs about 100kg so is true terrazzo. I’m not too worried about the repaired bits continuing the stone pieces, they can just be white.
Thanks in advance!
Re: Repairing Terrazzo Table
Welcome to the Bunnings Workshop community @jessss. It's sensational to have you join us, and many thanks for your question about repairing a terrazzo table.
For repairing the chips, you could try using PC-11 56g White Epoxy Paste. It’s durable, easy to work with, and should blend in well since you're not concerned about matching the stone pieces. Just a heads-up—when mixing the epoxy, be careful not to use too much of the dark catalyst, as it can turn the paste grey. Also, make sure to clean the chipped areas thoroughly before applying the epoxy for the best results.
Great thanks Mitchell! I will look into the epoxy.
