Is it safe to use a Specrite Golden Teak Acacia Multi Use Panel as a chopping board?
seldy
Hi Bunnings community,
I wanted to get some confirmation whether the other Specrite boards are food safe?
I'm interested in using the Specrite 1200 x 405 x 18mm Golden Teak Acacia Multi Use Panel
From this thread, the SpecRite FJ Glulam Spotted Gum panels was not food safe and this thread, another community person did make the cutting boards from the SpecRite FJ Glulam panel.
Thank you,
Seldy
Re: Is it safe to use a Specrite Golden Teak Acacia Multi Use Panel as a chopping board?
Hi @seldy
Thanks for sharing your question about the Specrite 1200 x 405 x 18mm Golden Teak Acacia Multi Use Panel. Please allow me to double check with our suppliers regarding its suitability as a chopping board. As soon as I have more information regarding the panel, I'll get back to you.
Thank you for your patience.
Noyade
Kind of a Big Deal
"I wanted to get some confirmation whether the other Specrite boards are food safe?"
I too, am hoping the feedback from @EricL is positive, @seldy
Unfortunately - I have already transgressed...
Hi @seldy,
The Specrite 1200 x 405 x 18mm Golden Teak Acacia Multi Use Panel does not come with a food-safe coating on it as it is a multi-use panel. However, I've had a response from the supplier stating that the panel can be sanded back to bare timber and a food-safe oil such as Feast Watson 250ml Kitchen Timber Oil applied to it.
seldy
Hi @MitchellMc @EricL
Thank you for following up with the supplier and confirming the details!
I'll go ahead and sand back the original coat then apply a food grade mineral oil.
@Noyade semi good news
Seldy
