I'm about to do a tile backsplash on our kitchen. Part of the area that will be tiled over is a melamine board wall, which was part of a corner cabinet that we remove. The area within the red box below is where we want to tile. Can I tile straight on top of the melamine board wall or do I have to cut that part of the board out?
Thank you.
Hello @wellz
You can either cut and remove that melamine wall in order to expose the original plasterboard or glue and screw a tile underlay sheet over the melamine board.
Thanks @EricL! Tile underlay sheet is probably the easier option. Can you provide a link to a suitable product?
Also how do I cut it to size as well as cutting a hole for the power point?
Hi @wellz,
You can use Villaboard to line that wall before tiling. It's similar to tile underlay and can be cut with a score and snap knife. You could cut out the powerpoint opening with the knife as well, or a multi tool would be another tool you can use.
Thank you @MitchellMc !
I understand that Bunnings doesn't do Villaboard cut in-store. So looks like I'll have to cut it myself so it will fit in the car.
What screws/nails would you recommend to install the Villaboard? Also would I need glue as well or nails/screws are enough?
Hello @wellz
I suggest using Selleys 350g Heavy Duty Liquid Nails along with a UNi-PRO Skeleton Caulking Gun. In regards to the screws, I recommend using Zenith 6G - 18 x 30mm Needle Point Gold Passivated Plasterboard Screw in order to prevent pinching the surface of the Villaboard.
