instructions
black washer in wrong place
We got one and this is the first time with such things. It talks of using two washers but only supplies one. And the one they supply if used on either of the ends wouldn't all the screw down thing to screw down so that couldn't be what it is for.
So - where/how to use the black washer they supply?
where/what washers to complete a watertight fitting with these things?
Hello @abrogard
Welcome to the Bunnings Workshop community. It's fabulous to have you join us, and thank you for sharing your question about the double bowl connectors.
Before we begin, your kit is suppose to have 3 particular o-rings. There are two flat o-rings and one bevelled o-ring. If any of these o-rings are missing please speak to the plumbing specialist at your local store. They can provide you with the missing o-ring or exchange it for a complete set.
Below are the general steps to assembly:
It is better to add extenders to the bottom of the sink trap rather than trying to adjust the double bowl connector. If your bowls are not at the same depth, that is the only time you will need to add an extender to the double bowl connector. If they are the same depth there is no need for any connectors or extenders. I've placed a basic diagram below. If you have any other questions about your double bowl connector, please don't hesitate to post them.
Please keep us updated with your progress, we look forward to seeing your double bowl connector installed.
Hi Eric, I have a question about joining the L connector to the T Junction. I have cut and chamfered the long pipe to the right length (I hope). I used sand paper to create the chamfer and finer paper to clean it up. I have put the bevelled washer into the t Junction and lubricated with liquid soap like it says on
the pack. Is the pipe supposed to go right into the t Junction, past/ through the washer? Because it's hitting the washer and not sliding in. I'm sure it's not supposed to just sit against it... that wouldn't create a stable, watertight join.
It's okay... I managed to get it in using Durex 😂
Hello @Kathy6
Welcome to the Bunnings Workshop community. Thanks for joining the discussion.
I'm glad you managed to slide the pipe into the o ring. However, for future assemblies, I recommend using Kinetic 15g Tap Lubricant. It's made to be used on o rings and rubber fittings in plumbing fixtures. If you run into any other issues, please don't hesitate to post a question.
Please make sure to post a photo updated of your double bowl fixture once you have hooked up. I'm sure our members would be keen to see how it's set up.
