Halfway through the kitchen revamp
Steps
123
Step 1
1/3
Remove, sand and clean the doors and cabinets.
Next Step
Step 2
2/3
Prime the surfaces with the Dulux Primer, then add the undercoat.  This was done with a roller.
Previous StepNext Step
Step 3
3/3
The used the spray version of the Zinsser undercoat
Previous Step
lockers
Cultivating a Following
Re: Halfway through the kitchen revamp
Thanks @Jason
Looking at moving through the house now and updating it.  After 13 years it is showing its age.  Only issue with the revamp is the Kitchen Mixer, installed it all and hooked it up straight from the box and the button on the head unit does nothing.  Is meant to have a changeable spray but only has one.  Need to see if there is any way to just replace the head unit rather than having to remove the whole thing again.
Was that one of our kitchen mixer taps @lockers? If so, I'd happily contact the manufacturer to see if just one part can be replaced. Alternatively, you can speak with the team in-store to see if a replacement part is available.
lockers
All good thanks @MitchellMc , was actually user error.  Found out you need to just about push the button through to the other side of the head to get it to switch sprays.
