How can I permanently remove grass?
brianhj
Hi all!
It's my first time posting here because I'm in need of serious help with my lawn.
I've tried laying cardboard, weed killer and weed mats after removing the sod but the grass won't stop growing.
Any ideas on how we can achieve this ground is much appreciated!
Re: How can I permanently remove grass
Hello @brianhj
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about permanently removing your grass.
Getting rid of grass permanently can be challenging, especially if it’s a hardy variety that keeps coming back. A strong glyphosate-based weed killer like Yates Zero from Bunnings works best when applied on a warm, dry day while the grass is actively growing. If regrowth occurs, multiple applications may be needed.
For a non-chemical approach, removing as much of the root system as possible and covering the area with a heavy-duty geotextile weed mat from Bunnings can help. A thick layer of organic mulch, such as sugar cane or pine bark, will further suppress regrowth while improving soil quality. If you’re not planting in the area, compacting the soil and adding pavers, stepping stones, or a layer of crushed rock like Deco Granite will create a durable, low-maintenance surface.
Even if you eliminate existing grass, wind-blown seeds can still take root. A pre-emergent herbicide like Yates Weed n’ Feed will help prevent new seeds from sprouting. Applying at least 10cm of coarse bark mulch will also make it harder for seeds to germinate. For paved areas, sealing gaps with Gap Sand or mortar helps stop stray grass from creeping in. Regular maintenance, such as pulling out any new growth before it spreads, will ensure the area remains grass-free over time.
Please remember to wear personal protection such as gloves, goggles and a mask when using sprays.
brianhj
Hi @EricL !
Thank you for the warm welcome 🙏🏻
Do you have any references on how I can compact soil as we don't plan on growing anything and just want to make it easier to walk. I've tried searching online but it's more on how to loosen compact soil instead.
Hi @brianhj
You could use a For Hire: Small Compactor - 24hr or use a Cyclone 254 x 254mm Tamper to compact the soil. Those are the only two methods I can think of for you to compact your soil.
brianhj
Rototiller vs Sod Cutter
Hello!
I'm looking to do some landscaping work but not sure if a tiller is the way to go or if I should use a sod cutter.
Basically, the plan is to turn the lawn into a shurb area. I'm not planning on laying new sod and really just want to rip up the grass roots to stop weeds from growing.
Re: Rototiller vs Sod Cutter
Hi @brianhj,
If you want to remove the grass and weeds then you'd need to use a sod cutter. Alternatively, you could poison the grass and weeds and then, once they've died, turn over the soil with a rototiller. If you're not a fan of using herbicides, you could cover the area with black Builder's Plastic for a month to kill the grass and weeds.
I would still recommend you use weed matting over the area and cut holes in it for your new plants. That will help prevent any weed seeds from germinating and populating the area. A thick layer of mulch will also help stop them emerging.
