Landscape a narrow side towards the fence
Abhi3
Hi All,
I have a narrow space which lies between the concrete layer and the fence. I’m trying to clear up the weeds and level up the area to the concrete floor height, so it looks tidy and probably a chance to add one or two garden beds  to have some plants  (thinking to have garden beds slightly above the concrete floor level so any debris from the floor won’t be accumulated). I would be glad if I can please get some suggestions on how I can implement the thoughts. Please suggest any other ideas which would make it look simple and tidy.
thanks,
Re: Landscape a narrow side towards the fence
Hi @Abhi3,
Can you advise how wide and deep this gap is?
I ask because any soil added to this gap would push against the fence, so if a large amount of material needs to be added, it is not something I would advise. Adding a basic retaining structure using timber sleepers will remove the lateral pressure on the fence and is certainly worth considering, but it will reduce the amount of space available.
It's usually not advisable, but if you stop direct contact between the soil and the fence, it might be ok if it is not too deep.
If you are happy to fill the space, you should attach some corflute along the fence and weed mat or geotextile membrane at the bottom of the trench. The corflute will not allow water through so it will protect the timber from issues relating to water in the soil, whereas the weed mat or geotextile membrane will allow water to drain downwards while stopping weeds from growing through.
Once prepared, you can fill the gap with garden soil and then add some plants. Alternatively, you could fill the void with stones and then add some planter boxes or raised garden beds on top.
