my lawn has almost completely died. I wasn’t sure if it was root rot from incredibly excessive rain or pests. I have sprayed for lawn grubs. Lawn area now almost a mud area. Can I grow eg rye grass as a cover while I’m waiting for grass to re grow. I can see some small green shoots starting to appear. Any ideas appreciated. Thanks. Janelle
A warm welcome to the Bunnings Workshop community @janelle7. It's great to have you join us and we trust you'll get loads of helpful advice for this project as well as many others to come in the future.
Could we please trouble you to share some photos of your lawn so we can see the condition it is in and better suggest next steps? It's certainly a common scenario, but some photos and an indication of where you are based would help members.
Many thanks,
Hello @janelle7
Thank you for sharing your question about repairing your lawn. I'm afraid the area around the playground set has been totally worn out. In order to repair the area, you can either put new turf slabs or seed the area with new grass. If you choose new turf slabs it will take approximately six to eight weeks depending on the weather before you can walk on them.
It will take around the same amount of time if you seed the area. But seeing as this is a high-traffic area due to the playground, have you considered covering the area with artificial turf in the meantime. I also suggest looking at the Swing Slide Climb 1 x 1m Green Rubber Play Paver. It can be installed around the play area providing cover and a safe surface for children to play on.
Please keep us updated with your progress, we look forward to seeing your lawn area covered and ready for use.
Hi again. Oops. I forgot to mention that this Bunnings play gym only went in last week. Grass was dead before then. Would rye grass or something similar be a coveting until grass regrows?
All good @janelle7. If the grass was already dead you've still got the same choice - lay turf or seed. Turf is obviously the quicker solution, but either way you are going to need to keep off the area for some time.
