How to revive Buffalo lawn?
Hey everyone just looking for some advice on how to get my lawn looking how it was when I first laid it atm it’s very thick and spongy with a lot of dead grass throughout it and some areas of my lawn have sunken what’s the best way to get it all level again and do I need to Reno my buffalo?
first photo is where the level has dropped and second photo is where I think it’s dead or lacking nutrient maybe and third is a close up of second, any advice will be helpful and I’m open to try anything to fix it thanks in advance!
- Labels:
Gardening
Lawn
Planting and Growing
Re: How to revive Buffalo lawn?
Hi @bax,
There are 3 steps I would recommend, dethatch, aerate and top-dress.
The layer of dead grass is called thatch. A layer of dead and living organic material, like grass clippings, stems, and roots, accumulates between the soil and the actively growing grass blades. Removing this layer of material will help the grass breathe and absorb nutrients more effectively, which will in turn create a thicker healthier lawn. You can remove this thatch using a Cyclone Timber Handle Long Thatching Rake or Ryobi One+ 18V Brushless Cordless Scarifier OSF1835BL.
Once your lawn has been dethatched, it will look quite bare and, in most cases, extremely dry and brown. Do not worry, this is all part of the process.
Check out How To Dethatch Your Lawn for some guidance on this process.
Now that the thatch has been removed, you should aerate the soil with a Trojan All Steel Spiked Aerator.
Check out How To Aerate And Top Dress Your Lawn which also covers the final step, top dressing.
Use a high-quality top dressing mix such as this Seasol 25L Lawn Top Dress Mix. Apply a layer approximately 10-15mm thick and spread with a Cyclone Top Soil Spreader aiming for a nice even surface.
Once top-dressed, water your lawn well using the mist setting to avoid any soil runoff.
Given a few days of sunlight, the lawn will start to repair and fill out and within a few weeks it will look brand new again.
Subject | Author | Posted | |
January | |||
March | |||
August 2023 | |||
October | |||
May |
