Findon1
How to lay new lawn?
Im after some advice on installing new lawn in this area. At the moment the soil is 150mm below the pavers. How much soil would
I need to remove to add sandy loam. Thanks
Re: new lawn preparation
Hi @Findon1,
If you wanted a small step down from your pavers, you could remove some material, but the level right now is near perfect for your new lawn to sit level with the pavers.
A turf slab is usually around 50mm thick, and you'll want around 100mm of topsoil making the current height of the soil ideal for the additional thickness of materials.
Check out How To Lay Turf for some further guidance.
Findon1
Thanks for your help.
