I am building a water feature with 2 cascading pots.
The higher pot is spilling into the lower pot.
There is a fountain in the higher pot and a return inlet pipe feeding that top fountain pump from the bottom pot.
I have an aquapro 1050 with the
Hello @igooba (Peter)
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your water feature.
Would it be possible for you to post a photo of your water feature. It sounds very well setup, but I believe that the pump should be positioned at the lowest point to prevent auto siphoning.
A large pump will often have a priming chamber that allows the pump to suck up the water even if there is air in the line. Unfortunately, small submersible pumps don't have this feature.
Instead, they work by gravity, if the pump and inlet pipe is at the lowest point in the water, there will always be water present even if the pump is off. For example, if the large pots are in a catch basin and the pump is under the waterline in the catch basin then air will not enter the pump. The water in the outlet hose will go down to the top of the pump but will not affect its performance.
However, we'll be able to give you better advice once we see your water feature set up.
If you have any other questions, please let us know.
If I’m reading your setup correctly, you’re running a siphon from the lower pot. To make this work properly, you’ll need to fit a 12 mm single non-return valve. This valve should always be installed at the lowest point of the return line and positioned below the water level in the pot. By placing it there, you’re ensuring two things: first, the water already in the pipe won’t be able to run back down into the pot, and second, you’ll avoid any air gaps forming between the valve and the water supply.
If the valve is fitted too high up, or above the water line, the siphon can easily break as air gets into the line. Once that happens, you’ll find the system unreliable because the pipe won’t stay primed. Keeping the valve low and submerged keeps the siphon charged and guarantees a steady flow.
It’s also worth checking that the valve you use is a good quality one, because cheaper valves can leak slightly, which again will allow the siphon to lose prime over time. A proper non-return valve fitted in the right position will make the whole setup much more consistent and hassle-free making it instantaneous between cycles
Hello @scottyp
Let me tag @igooba to make them aware of your recommendation. Thank you for sharing your knowledge and experience in regards to water feature pumps.
Were keen to hear more about all your projects and plans around the house and garden. Please feel free to reach out whenever you need assistance or would like to share a project with the community.
