3m poly tunnel for veggie patch
hello there,
Would like to ask a question about 3m poly tunnel for veggie patch.
does this 3m poly tunnel for veggie pat fits the width of 600mm? As per its details, its width is 1000mm and I have veggie bed of only 600mm wide.
thanks
Sukh
Re: 3m poly tunnel for veggie patch
Hi @sukh1,
Welcome to the Bunnings Workshop community, it is great to have you with us.
I am guessing you are referring to the Maze 3m Garden Poly Tunnel. If so, it will not be suitable for your 600mm wide veggie patch.
Might I suggest having a look at the Saxon 3m Greenhouse Tunnel With Cover. It's stated dimensions are still ever so slightly over 600mm, however it should be far easier to bend slightly to fit your requirements.
You might also like to consider Coolaroo 0.9m x 10m Pre Packed Garden Cover as an option, however it would require building some sort of frame to keep it up off your plants.
If you have any further questions, please don't hesitate to ask.
