Do you need to wash a new garage floor before laying epoxy?
Hello. I am a new member to this community. We need help with our garage. We are planning to apply epoxy prior to moving. The garage is new. Do you think we need to pressure and acid clean it prior to applying? From the prep to the final coating, how many days is the process and curing time?
- Labels:
Cleaning
Flooring
Painting
Tools and Materials
Re: epoxy project
Welcome to the Bunnings Workshop community @LJ1. It's sensational to have you join us, and many thanks for your question about epoxy coating a garage floor.
You'll need to follow the directions provided with the paint you select, and typically, that includes cleaning and acid etching. Here's a helpful guide: How to apply epoxy to a garage floor.
If you were to use the Dy-mark epoxy kit as shown in the guide above, then you etch the concrete and wait 72 hours for it to dry. If it passes the moisture test, you can move on to coating, but if not, it would be another 24 hours. The next day, you'll be coating. It could require one or two coats. You'll then need to allow 24-48hrs before light foot traffic. So, all up at a minimum, you'd be looking at at least four-five days from start to light foot traffic.
Re: epoxy project
Would you kindly list the needed materials to buy for etching until final coating?
Thank you
Re: epoxy project
Hi @LJ1,
The materials are mentioned in the How To guide I linked above, but I'll include them here for your reference:
- Degreaser (if needed)
For tools you'll need:
- Scrubbing brush or broom
Re: epoxy project
Thank you
Re: epoxy project
Final finish of the project. Very happy with the result. Thank you for your help. I just want to ask if it is needed to apply a top coat such as a gloss finish? What is needed and does it provides more non-slip?
Re: epoxy project
Hi @LJ1,
It looks great, you should be very proud of what you have accomplished.
While not 100% needed, a clear coat over your epoxy can add an additional layer of protection to the surface. You might like to check out Rust-Oleum Clear Gloss EpoxyShield Premium Concrete And Garage Coating as an option.
While it does not contain grit, it will still be a strong non-slip coating that should be perfectly fine on a flat surface.
Subject | Author | Posted | |
May 2021 | |||
February 2023 | |||
October 2021 | |||
February | |||
September |
