I’m purchasing a 3 x 1.51m shed
I need to build a base for it but Im unable to have a permanent foundation
have decided to build a wooden foundation
I need to know what wood to buy that will hold up to the elements
what thickness wooden to suit the size of shed
how far I should have the spacing to then add flooring
And any other suggestions or tips would be greatly appreciated
thanking you in advance
nick
Basically your building a mini deck of set dimensions. So to advance your planning look up deck projects and best how toos. For starters use H4 treated pine for the ground timber as a guide.
Others will be able to reference you too deck building resources soon
Hi Nick (@stewbiedoooo),
It should be noted that most shed manufacturers will not offer a warranty on a shed that is not installed on a concrete base. You can do it, but it is unlikely it will be covered by a warranty.
As @Jewelleryrescue has already mentioned, you are essentially building a timber deck, so the principles of deck building apply.
You might like to check out the following articles for some guidance.
You can look at the Absco Sheds 1.52 x 0.78m Timber Flooring Kit as an example of what would be required.
If it is in direct contact with the ground, you should use H4-treated timber. If it is elevated, you can use H3-treated timber.
Your joists should be spaced 450mm apart to support your flooring, which should be H3-treated to resist weathering.
A frame made from treated pine sleepers seems like a good option.
