How to support shelves in walk-in robe?
dqlproperty
I am doing a walk in robe melamine shelving wrap around what is the best way to support shelves for linen
Re: walk in robe
Welcome to the Bunnings Workshop community @dqlproperty. It's wonderful to have you join us, and many thanks for your question about attaching shelving.
Are you planning to support the melamine shelving with wall brackets, or will you use side panels with pre-drilled holes for support pegs? Both options are effective, but the best choice will depend on the style you're aiming for and the weight of the linen you intend to store.
Re: walk in robe
Gday Mitchell
Its going to be L shaped i am using support timber under shelves just 1x2 in around screwed into studs it will be
350 wide melamine on left wall and back wall will be 500 wide
Were i am concerned  is were 2 meet should put brackets in
That corner to support the 500 melamine
If you understand  what I'm saying
Re: walk in robe
Hello @dqlproperty
I definitely recommend putting in a support bracket where the two shelves meet. This will prevent it from sagging or bending out of shape should weight be applied to it for an extended period of time. I've drawn up a sample image just to give you an idea of how it can be done, please note that the measurements are for reference only, please adjust them to your needs.
