replacing shower channel
hurlexx
 hi Everyone,
I'm wanting to install this second hand shower we've had for some time but need some new wall and floor channel to fit it to, does bunnings sell this? It joins on the left of the door with the current right angle channel
Dimensions:
Door: 824w x 1877t x 25mm thick
Wall: 795w x 1877t x 12mm thick
Re: replacing shower channel
Hi @hurlexx,
Thank you for your question.
I'm fairly confident you can use this Metal Mate 12 x 12 x 1.5mm 3m Aluminium Channel and this Metal Mate 25 x 25 x 3mm 3m Aluminium Channel.
Assuming your measurements are bang on, they should slot straight into the channels, which can then be sealed with clear wet area silicone.
