how to unlock a jammed bathroom door
jamesw74
Community Newcomer
My toilet door has locked itself from the inside. I have tried to push the pin out but it will not move at all. In the process I've broken the handle off and still cannot open door or get lock pin out. What do I do now? Photos below. I do not know the brand of the door handle.
Re: how to unlock a jammed bathroom door
Hello @jamesw74
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your door lock.
Since you've managed to remove the outside handle, you should technically be able to push the inside assembly off the door leaving the door latch in the door. Your objective is to push the locking pin out to release the latch that's inside the door. One other option is to use a nail and hammer to push the locking pin out on the other side. this will allow you to then turn the axle of the latch and door to open.
If it still refuses to open, I suggest engaging the services of a locksmith to unlock the door for you.
