hand held bidet
musama
hand held bidet
How can i install handheld bidet with the tap in cistern. There are no other taps around the toilet.
Can i use t valve in cistern and connect bidet and drill a hole in cistern for bidet.
is it easy to drill cistern or it can shatter?
thank you
Re: hand held bidet
Hello @musama
Just a friendly reminder that any plumbing work must be carried out by a licensed plumber for safety and compliance.
Thanks for sharing your question about installing a bidet around your toilet. If there are no other taps around the toilet it will need to be linked from the inside. You'll definitely need to engage a plumber to install your bidet spray, they will be able to drill through your cistern and connect from there or they will run a new pipe from the inside bottom of the toilet. It will be complicated and involved because it sounds like you have a back to wall toilet suite. Which means that the plumbing fittings are all hidden in the back of the toilet.
