How to connect the water inlet from the wall with the toilet's water inlet?
etang
Hi, The water inlet from the wall is approximately at 710mm height from the floor. The toilet's water inlet is at 716mm from the base of the toilet. Is there a part that I can buy to match the water inlets? Sorry the measurement is approximate depending on how I measure it and what floor we are going to use. Thanks.
Re: What parts can match/connect the water inlet from the wall with the toilet's water inlet?
Hi @etang,
A toilet is generally connected to a water inlet with a Stainless Steel Braided Hose Water Connector, so the height of the fittings shouldn't really matter.
Unless your toilet is entirely different to the ones I've dealt with, this should be the solution, but if there is some reason this wouldn't work, please let me know so I can assist further. Some photos would also help.
Let me know what you think.
