Quickest and easiest way to remove tiles surrounding a bathtub?
Minitots101
Building a Reputation
Does Bunnings have a solution such as "grout dissolver spray" - - which I can spray on the tiles, surrounding the bathtub, and the tiles will fall off?   ...(it sounds like wishful thinking - but maybe this solution exists?).
Re: Quickest and easiest way to remove Tiles surrounding a bathtub
Hello @Minitots101
Thanks for sharing your question about removing grout. Can you imagine a liquid spray that would melt grout in just a few minutes, that would be a fantastic invention. Unfortunately, the fastest method is still by using a Multi Tool in combination with a Kango 64mm Diamond Grit Boot Multi Tool Blade and a steady hand.
My best advice is to cover the vanity, toilet and other areas with drop sheets held in place with painter's tape. This will prevent your entire bathroom from being covered in grout dust.
Here is a handy step-by-step guide: How to grout tiles
