Hi there,
https://www.bunnings.com.au/magnet-chrome-wall-mount-toilet-roll-holder_p5166386
Just wondering how do I install this if I buy it?
Do I need to drill holes in tiles ?
Thanks.
Hello @kdar
Thanks for sharing your question about the Magnet Chrome Wall Mount Toilet Roll Holder. This toilet holder needs screws to be mounted to the wall. I suggest using the Ramset 6 x 38mm Universal Anchor - 6 Pack to mount your toilet roll holder. This screw set will work on plasterboard, timber and brick walls.
The general steps are to test the wall first with a single screw to find out if it is hollow or there is timber behind the spot you're mounting on. If there is timber just use the screws from the kit. If there is nothing behind the plasterboard wall, you'll need to drill a few holes and use the red wall plug that came with the Universal Screws.
Here is handy guide that will help: How to hang just about anything
