How to replace cracked floor tiles? Does the adhesive need to be FULLY removed?
Torquay
Hi all, I’m replacing a few cracked tiles and noticed in some that the tile comes away easily ( no back adhesive) but the adhesive on the floor ( concrete ) is well and truly adhered. As I chip away at the adhesive, or use a blade on a multi tool, it really is part of the floor. My question is… If there is enough space for new tile adhesive across the full tile, do I need to try to chisel the old adhesive off. I was going to remove all loose adhesive, scrape what I can off, I’ve then cut in  some cross marks for more adhesion, then paint with primer and simply re- glue a tile over the top?
id welcome any experienced thoughts? It is well and truly bonded to the concrete, so will a primed surface and tile glue be sufficient- ensuring there is full coverage of new glue?
Re: How to replace cracked floor tiles? Does the adhesive need to be FULLY removed?
Hi @Torquay
Please don't forget to post an update once your repairs are complete. I'm sure our members will be keen to see the outcome.
