How to remove spindle tap handle?
Adamg
Hi Folks,
I'm trying to remove the handle from a  Dorf spindle laundry tap. I've purchased a Kinetic Spout and Handle Repair Kit. However, I'm struggling to dislodge the handle which I sprayed with WD40.
https://www.bunnings.com.au/kinetic-spout-and-handle-repair-kit_p4920385
Seeking tips and advice on which way to apply pressure to remove.
Cheers,
Adam
Noyade
Home Improvement Guru
Re: How to Remove Spindle Tap Handle
Welcome to the Bunnings Workshop community @Adamg. It's brilliant to have you join us, and many thanks for your question about removing a tap handle.
It's great to see that the knowledgeable @Noyade has already sorted your question. I concur that green is the correct direction, as you are actually undoing the nut on the back. Green turns the nut anti-clockwise and backs it out of the handle.
If you haven't already seen it, check out this helpful step-by-step guide: How to replace a tap washer.
Please keep us updated and reach out again if you run into difficulties.
 Thanks very much @Noyade job done
