I need to move an existing vanity drain about 600mm from existing floor or bath drain to accommodate EnSite reno. The EnSuite is on concrete slab. The floor will be covered with tiles
Hi @boycebag,
Thank you for your question and welcome to the Bunnings Workshop community, it is great to have you with us.
Unfortunately, due to the licenced and regulated nature of the plumbing profession, you will have to contact a plumber to carry out this work for you. They will have the tools and expertise to carry out this work in line with construction codes and regulations.
You might like to check out HiPages or True Local to find a plumber local to your area.
Thank you. Thought so.
