How to install Mondella Rococo tap?
redsta
 I recently brought these tap bits I installed last night but when I did you can easily just pull them off the stem there is a little hole at the bottom on the tap handles could this be a set screw hole no screws or anything in box so very confused any help would be greatly appreciated
Re: How to install Mondella Rococo tap?
Hello @redsta
Are you saying that when you put the handles on the spindle it starts to leak? Is the handle not reaching the spindle or is the cover flange preventing the handle from going on the spindle? There should be no leak when the handle is on. Can you please take a photo of the tapware with the handles on.
This will give us a better idea of what's happening with the handles attached. In regards to extending the spindle you might be able to use the Kinetic 28mm Ceramic Disc Spindle Extender. But it will make the spindle stick to far out of the wall.
