Just installed a new Shaw&Mason mixer tap and nothing comes out of tap when in full cold position.
Not problems with hot side of things.
Old tap was no problems except it was beginning to leak after 11years - good flow of all cold and all hot.
Swap the hose connections over @Rickard and If cold water flows when the mixer is on hot and nothing on hot then sounds like a mixer fault.
regards Nailbag
Welcome to the Bunnings Workshop community @Rickard. It's wonderful to have you join us, and many thanks for your question about sink mixers.
I'd suggest @Nailbag's troubleshooting advice is on the money. Also, double-check that you've turned both the hot and cold isolation valves back on under the sink and that the cold flexi-hose is not kinked.
