How to fix hole at the bottom of bathroom vanity?
Jleigh
 Hi, I would appreciate any suggestions on how to cover up this uneven hole at the bottom of our vanity. Our plumber had to make a bigger hole as the existing hole was not in the correct spot for the drain pipe to go through. Thanks
Re: How to fix hole at the bottom of bathroom vanity?
Hello @Jleigh
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about your vanity.
I've run into this situation before where I was sure that I was drilling into the correct area of the vanity. Luckily my wife is very forgiving and takes every opportunity to remind me of this error. I suggest using the Kinetic 295 x 210mm White Flat Self-Adhesive Cover Plate to cover the other holes drilled into the vanity.
I suggest using a compass to draw a 42mm diameter circle where the drainpipe will be positioned. Cut the circle out with a craft knife and then cut a single center line going to the circle where you can slip the 40mm drainpipe in, you can then paste in place.
Jleigh
Thanks Eric. I will give that a go 👍🏻
