I have a small room where there is bare concrete. I wish to lay vinyl tiles but first need to create an even surface.
I want to use something like LANKO floor leveller. Can anyone advise:
Approximately how much area will 20kg LANKO floor leveller cover? I have an area of something like 5sq mtrs, so need to know how many bags to buy.
Do I need a primer with this product? If so, which one to buy?
A question for Bunnings: When will you get this product back in the Eltham store?
Any other advice about using this or similar product welcomed.
Hi
I got the leveller, but was trying to investigate getting a mixing tool which fits onto a drill, as recommended in the chat.
This proved to be impossible.
I eventually found a tool in the Tool Shop at Mill Park, but it doesn't look like I expected; appears too large, and the other end is a screw head, which clearly is not intended for a drill. I have attached a photo of the tool.
Hope I can get some advice on this.
Is there an appropriate tool to use with a drill for mixing the floor leveller and where can this be obtained?
Hi @bernardh,
This UNi-PRO Large Paint Drill Mixer will be suitable and fits into a 240V electric drill. The budget-friendly XU1 500W 13mm Hammer Drill will work if you don't have a corded power drill.
You'll find these types of mixers in our Paint Department.
