I am about to renovate my bathroom and need to isolate my shower, basin and bath so the rest of the house has water but so that I can gut my bathroom.
How can I go about that?
Compression stop?
End cap?
Ball valve?
Shark bite?
or something I haven’t came across yet?
photos of the wall and fitting that went into the wall. TIA!
Hi @ebonybasten,
Thank you for your question about isolating the water supply to your bathroom.
Unfortunately, any time work needs to be done on a pressurised water supply line, you'll require the assistance of a suitably licenced plumber.
You might use this as an opportunity to open a relationship with a plumber for any ongoing work in your bathroom renovation.
You can use a service such as HiPages or True Local to find someone operating in your area.
Incase anyone else needs to know how, I ended up buying brass end caps and plumbers tape and capping the ends off. I had a plumber come through a few days later to quote for the rough in and end fitting and I asked him if what I had done was ok and he said there was no issue. So, easily diy’d until the plumbers come to do the professional work.
