I'm looking at using a Specrite 1200 x 405 x 18mm Golden Teak Acacia Multi Use Panel as a vanity top in my bathroom. It says on the label to use caution in wet areas and follow the instructions provided, but I can't see the instructions until I buy it. I assume it's just regular oiling and so on.
Has anyone used this in the bathroom?
https://www.bunnings.com.au/specrite-1200-x-405-x-18mm-golden-teak-acacia-multi-use-panel_p0456530
Hi @RenoRaine,
You'd typically want to use a hard waterproof coating on timber surrounding a sink like Cabot's 500ml Satin Water Based Cabothane Clear Polyurethane Timber Varnish. Oil will help prevent damage but you'll still experience water staining and possibly decay.
The instructions state that a hard wax should be used for protection, but the panel is not designed for wet areas.
I've used these panels in a laundry and chose to go with polyurethane instead of wax. They've held up nicely under damp conditions.
