Best option for rangehood?
manjish
Can i please have some option of rangehood which suits my space. The measurement is 90 cm length, 50 cm width  and 17 cm height. Got confusion regarding the rangehood options. 
Re: best option for rangehood
Welcome to the Bunnings Workshop community @manjish. It's splendid to have you join us, and many thanks for your question about rangehoods.
In order to find a rangehood that would suit your existing cabinetry, you would need to take some careful measurements of the cabinet and compare them to the technical drawings of the range hood. Something like the Bellini 90cm Stainless Steel Slide Out Rangehood would be in the right ballpark.
I've included the technical drawing below. You would need to measure the inside of the cabinet above to ensure the 850(W) x 280(D) x 135mm(H) internal section can be recessed within the cabinet. Your current rangehood is likely just attached to the base of the cabinet above, and the ducting goes through it. Modern designs are mainly recessed and enclosed within the cabinet.
Hello @manjish
Yes, you can install the Esatto 90cm Matt Black Box Canopy Rangehood. However, please note that this is a stand-alone rangehood and does not require a cabinet. The cabinet you currently have must be removed before installing this rangehood. Also please be aware that the rangehood solid ducting is quite long so its important to check that you have the space for it.
manjish
I understand this will be a standalone does bunning tradie remove the cabinet as well. I am planning to hire bunning tradie to do the job.
Hello @manjish
If you are using the rangehood installation service, please note that this is a "like for like" installation service. They will not alter, cut or change your cabinet layout. You'll need to arrange the cabinet modification separately.
