What type of plug and strainer do I need for this kitchen sink. See attached photo.
Hi @GaryArmadale,
If you could measure across the top opening to give us an idea of the size, then we could point you to some options. It's likely to be a 50mm plug or you can go with a 50mm multifit plug. This 50mm stainer should also fit.
The diameter of the top is 88mm.
The diameter of the bottom is 58mm.
Regards
Gary
